I've now submitted 2 files with the following error.
"The RINEX data submitted to OPUS contains data taken from more than one
location. This can be verified by opening up your RINEX file and
searching for "MARKER". OPUS will only process data taken from one
location. Try separating the data into individual files and then
re-submit the data
Aborting..."
I'm just using the RINEX program inside TBC and it is giving me double MARKERS. I've tried deleting one of the MARKERS but to no avail.
I've not run up against this before. I've used RS for a while now with no issues as long as I get 20 or more minutes. This is new to me.
Any advice?
The online teqc will remove those double markers. I have used it to even remove double markers that I cannot see, but it sees them and asks if I want them removed I say YES and then submit and get an OPUS-RS solution.
Google "UNAVCO teqc".
