I'm having issues with my Lat and Long being rejected by the NGS conversion software.
Does anybody have any ideas what I could be doing wrong?
I am entering in DMS as shown, which is how it arrives in an OPUS-RS report
"degrees, minutes, seconds and decimals (xx xx xx.xxxx)"
XX XX XX.XXXX
XXX XX XX.XXXX
DATE: July 15, 2014
POINT 1
LAT: 43 36 40.43423 0.004(m) 43 36 40.46425 0.004(m)
E LON: 273 27 48.57772 0.008(m) 273 27 48.54398 0.008(m)
W LON: 86 32 11.42228 0.008(m) 86 32 11.45602 0.008(m)
EL HGT: 145.275(m) 0.008(m) 144.220(m) 0.008(m)
ORTHO HGT: 180.087(m) 0.017(m) [NAVD88 (Computed using GEOID12A)]
POINT 2
LAT: 43 36 43.15620 0.004(m) 43 36 43.18622 0.004(m)
E LON: 273 27 47.82094 0.007(m) 273 27 47.78720 0.007(m)
W LON: 86 32 12.17906 0.007(m) 86 32 12.21280 0.007(m)
EL HGT: 144.731(m) 0.052(m) 143.676(m) 0.052(m)
ORTHO HGT: 179.545(m) 0.054(m) [NAVD88 (Computed using GEOID12A)]
I am using this calculator, but have not had any luck
http://www.ngs.noaa.gov/cgi-bin/IGLD85/IGLD85.prl
Inputting as described, I get an error message, but convert to decimal degrees and inputting this:
I rec'd this:
Thank you for your help!!!!!
You are not the only one. Every time I use that I have to do the example and change the numbers. The first time I enter something it always seems to be rejected. The difference in my area is almost too small to mess with most of the time, but at least I say that I did it.
I will say this, very happy to have the conversion tool though. For the longest time I could find no conversion between NAVD and IGLD. Finally found a single webpage published though the Detroit army corps and ran with that info for years until I found this tool.
