Thanks.
I'm just a regular guy, my pronouns are FNG, BFR, and WTF, and I'm almost as excited about Trimble GNSS and TBC as Nate is about Javad.
I did get the same result as R S Mayer when doing it that suggested way.
Typically I just drag and drop files into TBC, but when I did that, my results were different vs. using the import command.
TBC is turning into a monster of a program, and this could be one of those things that fell through the cracks.
Lefty
Now, at the bottom of the import window click on settings then click Force Static to turn it on. Now your can import the 2A & 2B files.
Bingo!?ÿ That's the magic bullet.?ÿ The test vectors all processed cleanly with good stats.
Thanks so much for finding that.?ÿ I figured there must be a way to do it, but I wasn't having any luck on my own.
Good to hear that solved your problem. The field crew needs to setup the RTK & Logging style correctly and start the stationary receiver as the base using that style. That should allow the files to process without the work around.
What is your storage epoch rate in base and rover. If they don??t match that could be an issue. Or maybe some bug in TBC. ?ÿI saw where you stated that the time was common time so that rules that out. ?ÿBut when I do PPK I like 1 second epoch at base and rover. Especially when you might do a topo type shot with only a few epochs.?ÿ
I didn??t read your other 5,000+ posts to get a feel for how well versed you are with Trimble products.
My experience with Trimble hardware is mostly limited to campaign-style static missions using 4000-series receivers, so my familiarity with Trimble data collectors and modern receiver is pretty minimal.?ÿ I appreciate the explanations!
Very good thread. I am not familiar with the GNSS side of Trimble, but now I feel like I stayed in a Holiday Inn last night.?ÿ
@mightymoe the file location storage has no affect on the stored data! The file is the same. ?ÿIt??s just if the collector walks away from the receiver during measuring a point, your data isn??t recorded. Always store in receiver.?ÿ
Nope, I will not store roving PPK or Data Logging roving in the reciever. Always in the DC. Way better.
