GNSS RTK Reports
skyraster
(@skyraster)
Hello Surveyors
I've some question about GNSS reports in your work. Do you use applications (software tools) for create reports from RTK measurements?
For example to create list of measurements with columns like local/wgs coordinates, normal/reduced heights, antenna height, pdop, hsig/vsig..etc or tables to make comparison between warp/teoretical and measured points, list of points made by offset or intersections..etc
In which format typical that reports are created? txt/rtf/pdf/html?
kind regards
Mark
Posted : June 6, 2014 8:02 am
lee-d
(@lee-d)
I use Trimble Business Center. They have a couple of useful reports that are in HTM / HTML format, and it is very easy to create customized reports in Excel from their spreadsheet views.
Posted : June 6, 2014 8:06 am
skyraster
(@skyraster)
Thanks for fast reply!:-)
I see - it isn't standalone app for only GNSS reports, but complex center for processing measurements. Good stuff.
I'm curious because some time ago, some of surveyors from my country want to write application for them (i'm software enginner & surveyor techician)- app to create GPS reports from files delivered from apps like Landstar (CSV,DB) Trimble (JXL) or SurvCE (RW5).
App has been finished (it supports also the Pentax RAW format, Leica XML and RTKP format from Android RTK measurement app), have good reviews and i'm wonder about preparing version for other countries with other language version, support for other local coordinates systems and geoid support (height corrections).
kind regards!
Posted : June 6, 2014 8:22 am
christ-lambrecht
(@christ-lambrecht)
For Trimble reports there is the free 'Ascii File Generator', it converts job files on the dc or on the desktop pc to html and ascii reports.
Chr.
Posted : June 7, 2014 6:46 am
