bluetooth problem w...
bluetooth problem with topcon hiper lite +
2 Users
fct487
(@fct487)
I am having trouble connecting my Bluetooth with my rover. Base is working fine not sure what happened everything was working fine I connected to Topcon receiver utility the other day to download some files trying a usb cable I don't know if I hit a setting or something but if I do connect with a cable to data collector with rover everything works fine so it has to be a Bluetooth setting. If I reset the nvram do you think that might do the trick or will that make for more problems? any suggestions?
Posted : May 30, 2014 1:48 pm
kjac
 kjac
(@kjac)
Do you have another rover or data collector so you can rule one or the other out? I would try deleting the Bluetooth connection profile for that rover unit on my DC and make a new one, then make sure you check the "discoverable" check box.
Posted : May 30, 2014 7:16 pm
