Alabama ALCORS
 dcn
(@david-c-newell-rpls-ls-cfm)
Is this system available without a paid subscription?
Can anyone give the steps to login?
Posted : 12/09/2017 12:23 pm
(@ozzy84)
no charge to connect
http://aldotcors.dot.state.al.us/SpiderWeb/frmIndex.aspx
link above to ALDOT CORS,
I did have to register, then with login & password no problem connecting.
Just saw your location, you may have trouble getting Fixed, 🙂
Posted : 12/09/2017 12:45 pm
 dcn
I have friend who is going to some volunteer work staking a parking lot, thought he might be able to use the network.
I registered and set up an account and found the IP address and port number for CMR+:
"NOTE : IP Address for all Products is 205.172.52.26 Connection Type TCP/IP ... AL Nearest CMR+ - CMR+ GPS and GLONASS 10002"
But DC (Trimble TSC2 with Survey Controller) is asking for user name and password and am not sure if it's the same as the login to site?
ozzy84, post: 446486, member: 9840 wrote: no charge to connect
Posted : 13/09/2017 4:24 am
(@ozzy84)
yes same as login to site, if your login or password is hard to key-in with DC, you may need to login with computer and change to something easy.
post back if problems remain.
hope this helps.
Posted : 13/09/2017 4:46 am
(@jerrys)
I connected to ALDOT today from my desk in my office and saw a fixed RTK position 53 miles from the reference position. If you are using Survey Pro, the mount point i have had the best success with is identified as LeicaMAX;LeicaMAX;1;...
Customers in the state have told me that they gave them various port number but 10011 is what works best for me.
Posted : 13/09/2017 1:26 pm
 dcn
Thanks
JerryS, post: 446626, member: 205 wrote: I connected to ALDOT today from my desk in my office and saw a fixed RTK position 53 miles from the reference position. If you are using Survey Pro, the mount point i have had the best success with is identified as LeicaMAX;LeicaMAX;1;...
Posted : 15/09/2017 6:15 am
