A dozen, a gross, and a score
Plus three times the square root of four
All divided by seven
Plus five times eleven
Is ______ squared, and no more
Can you write the equation and fill in the blank?
9
12 +144+20+(3*2)/7*55??
Cell phones suck at math
Ambiguity is the father of trouble
For meanings that are triple or double
Lead to systems failures
And managers' wailures
Turning good ideas into rubble.
There once was a man from Nantucket....
@flga-2-2 50
Stop teasing...
I'm just a biologist. ?????ÿ
Agreed.
And I'm amazed I could get that answer before reading yours, without paper. I'm getting less able to hold stuff in my head.
..that carried his lunch in a bucket..
After eating his lunch
With a chew and a crunch
He'd pull out a bottle and suck it.
Nine to the first challenge and 50 to the second.
A test of reading comprehension, not arithmetic, on a simple interpretation.
However, what if the man came from a side path that joins in the direction going to St. Ives? We don't have enough information to fully analyze this situation.
@holy-cow?ÿ This simple little nursery rhyme has been around for several hundred years (at least).
The way I was taught 70+ years ago, was "As I was going to St Ives, I met a man...
So if you were going he must have been coming from St Ives, because you met him.
So the answer to your last line "How many were there going to St. Ives"
ONE!
There are other problems like this but some people want to read things into the problem.
Remember the hanging cable problem?
JOHN NOLTON
PS?ÿ do a internet search (like Bill93 does to answer) and see what you find.
