Today's office phot...
Today's office photo
5 Users
(@leegreen)
Noble Member Customer
Preparing for 2,200 cubic yard concrete pour.
Setting 1.5" diameter anchor bolts, 8ft long. Walking on #8 rebar spaced 12" on center and 7ft above the mud mat.
20200424 122634
20200424 122627
Posted : 02/06/2020 5:14 am
not my cup of tea!
"Walking on #8 rebar spaced 12" on center" my suggestion, as it is done here, use chunks of thin plywood like snowshoes. Less hazardous, and much faster.
Posted : 02/06/2020 7:35 am
(@party-chef)
I am pretty nimble walking around on a mat but I like the snowshoe idea!?ÿ
Iron Workers are pretty good at fishing tools out of the cage, I hate the feeling of dropping things in environments like that.
Hope the tolerances are something reasonable...: 🙂 ?ÿ
Posted : 02/06/2020 11:33 am
(@leegreen)
The tolerance per Engineer is 1/8", which is unachievable with current procedures. If they really need to be that accurate, then the contractor should core and grout each bolt. It is difficult to control 2000+ yards of concrete. I believe they are misinterpreting the definition of anchor bolt tolerance. It is my understand the plans call for the bolts to be measured at an accuracy of 1/8", which is still a tall task.
Today I measured over 100 DYWIDAG's. These are 1.5" dia anchor bolts (elliptical) with a very coarse left-hand thread. They look like large rebar.
20200603 074622
Posted : 03/06/2020 9:11 am
(@tim-v-pls)
Reputable Member Registered
this is my jam... love big pours.
How do you like that prism-holder thingy (I can't recall the actual name at the moment)? I've been considering one for quite a while and just haven't pull the trigger on purchasing.
Posted : 03/06/2020 9:29 am
(@leegreen)
You are referring to the Marksman. It works great. Just make sure the bottom feet are secured. Dropped a foot yesterday from the top 7ft down to the bottom of the mat. I had to send a skinny guy through the 12" cage to retrieve it.
Posted : 03/06/2020 10:34 am
Illustrious Member Registered
This job just looks like no fun at all for me.
Glad you seem to excel with this type of work.
Thanks for sharing.
Posted : 03/06/2020 11:23 am
(@tim-v-pls)
@leegreen i often remove my vest working on deep mats 'cause nearly every time I'll drop a scribe or tape measure or something... I've dropped my controller a few times too. grr...
Posted : 03/06/2020 12:11 pm
Share:
