> Yes, in StarNet use the T input records to make a traverse. It still uses least squares to adjust but gives you the traditional closing line and ratio.
I think what I wanted was the closing call and ration BEFORE adjustment, but this seems to have adjusted away. The coordinates have changed from what they were before.
I thought it might be because the initial data closed perfectly (I haven't checked), but if it closed perfectly, why would any adjustment happen at all?
The next section is "Traverse Closures of Unadjusted Observations (Beginning and Ending on Adjusted Stations)" Whatever the heck that means.:-/
Posted : 21/02/2015 11:38 am
