Using CS-15 as a base
2 Users
(@redglobe)
Hello,
I was wondering if anyone knows how to configure a Leica CS-15 rover into a base to record static data.
Thank you
Posted : 19/11/2018 9:26 am
(@eric-kara)
You don't need to be in the base menu to record static data, however the settings are in the same menu.?ÿ
main menu
  1. Instrument
  2. GPS setting?ÿ
  3. Raw data logging
  4. make sure "log data for post-processing" is checked
  5. choose if you want to log the data to the controller or antenna
  6. Make sure "log data when" is set to "static"
  7. Choose rate and press OK
    Now we need to turn of "Auto Stop" so the instrument will keep logging till you are done?ÿ
  8. Instrument
  9. GPS setting?ÿ
  10. Quality Control
  11. uncheck "automatically stop point measurement"?ÿ
That's it?ÿ
Posted : 19/11/2018 10:17 am
(@redglobe)
thank you
Posted : 20/11/2018 11:59 am
