Turn a non robot into a robot using parini bluetooth
7 Users
(@daneminceyahoocom)
Honorable Member Registered
Is it possible to turn a non robot 5600 into a robot using surveypro a recon data collector with bluetooth and a parini blue tooth?
thanks for your help
Posted : 12/05/2022 8:07 am
(@rover83)
Noble Member Registered
If the instrument isn't already a robotic model with servos/drives in it, probably not.
If you're just looking to use Bluetooth instead of the UHF radio on a robotic total station, you might start with this instructional video.
Posted : 12/05/2022 8:42 am
(@chris-bouffard)
No, it's not mechanically capable to act as a robot.
Posted : 12/05/2022 9:05 am
Illustrious Member Registered
I was not aware that there was such a thing as a non-robotic Trimble 5600, although it was always possible to use one in non-robotic mode?ÿ
Posted : 12/05/2022 9:54 am
I was thinking that it could not be used to search for prism or turn to a point where those commands were issued remotely. I did think that using the systems autolock feature it would?ÿ follow a prism till lock was lost. thanks for your help. This was a recent purchase and now I understand why it was so in expensive, the unit does not have an internal radio.
Posted : 12/05/2022 10:09 am
(@tim-v-pls)
Reputable Member Registered
@norman-oklahoma I have a non-robotic, autolock 5603 circ 2002, used exclusively for 2 person construction layout. At the time of purchase, it could be upgraded to robotic by adding the radio. Likely that option isn't currently supported.
Also have a fully working robot 5603 cir 2006, just sitting as a backup... I bet it feels lonely.
Posted : 12/05/2022 10:25 am
@tim-v-pls where you get your 5600's?ÿ serviced? thanks
Posted : 12/05/2022 12:34 pm
(@tim-v-pls)
@daneminceyahoocom Well... they've been sitting unused for years so haven't serviced them. I just turn them on every once in a while to see if they fire up. So far they always do.
Local place, now a Frontier Precision store, had people who could service them but those folks have moved on. Not sure where I'd go now.
Posted : 12/05/2022 1:02 pm
(@jaccen)
@daneminceyahoocom?ÿ
https://www.seilergeo.com/
We use one of the Michigan shops.
Posted : 25/05/2022 11:20 am
(@kevin-hines)
Prominent Member Registered
@daneminceyahoocom
You might want to try https://www.monsenengineering.com/ for Trimble sales & service in your area.?ÿ Great group of people.
Posted : 25/05/2022 11:59 am
Share:
