I have a TSC2 with Survey Controller 12.50 on it. I use it as a network rover with a Trimble R6 and it has worked flawlessly for months. This afternoon, I stopped by to finish up a small survey and could not get it to connect to the network (Mississippi RTN). It keeps saying "Could not start base data". The TSC2 seems to be connected to the internet, but it will not connect to the network. I have not changed any settings since the last time I used it, it just is not connecting. Tuesday, when I used it last, it did do this one time, but I restarted the controller and it worked fine. That has not worked today. I saw where someone else had this issue, but the thread did not have a resolution for it. If anyone has encountered this before, I would greatly appreciate knowing how you fixed the issue as I have work that I need it running to complete.
Thank you
