trimtalk 900 operations manual
5 Users
(@dane-ince)
I am looking for a copy of the trimtalk 900 operations manual. Thanks for your help
Posted : July 28, 2012 9:40 am
(@robert-martin)
(@dane-ince)
Thanks Robert,but no
Robert thanks for the 450 manual. I need the 900 manual to find part numbers and accessories
Posted : July 29, 2012 10:01 am
(@robert-martin)
Dane,
Would any of these numbers help?
TRIMTALK 900 Equipment Sets
The TRIMTALK 900 radio modem provides a versatile means of establish a wireless broadcast network for real-time, high-precision GPS applications. Each TRIMTALK 900-based broadcast network can be configured to operate on one of seven different channels. The TRIMTALK 900 radio modem is certified for license-free operation in both the United States and Canada, simplifying the process of broadcasting real-time GPS data. No radio license applications or fees are required before use. Additionally, the low-power, multi-channel design of the TRIMTALK 900 reduces the chance of interfering with other local radio users. A TRIMTALK 900 wireless data network can use up to 5 repeaters depending upon broadcast information content and rate.
TRIMTALK 900 Base Equipment Set Part 23800-81
TRIMTALK 900 Radio Modem Part 23800-00
5dB Antenna with 0dB Tip Part 22882-00
7-pin Lemo to Radio Power Cable, 50 foot Part 21323
Mounting Bracket Part 25945-00
TRIMTALK 900 Repeater Equipment Set Part 23800-83
Battery Cable, 1 Camcorder Battery Connector Part 18542
Camcorder Battery Part 17466
TRIMTALK 900 Rover Equipment Set Part 23800-85
Rover Antenna with Backpack Mount Adapter Part 27525-00
7-pin Lemo to Radio Cable, 3 foot Part 21109
TRIMTALK 900 Base & Rover Equipment Set Bundle Part 23800-87
TRIMTALK 900 Base, Repeater, & Rover Equipment
Set Bundle Part 23800-89
Posted : July 29, 2012 11:42 am
(@robert-martin)
Here are a few more part numbers for the TrimTalk 900 Series
23800-81 TrimTalk 900 Base Equipment Set
23800-00 TrimTalk 900 Radio Modem
23800-83 TrimTalk 900 Repeater Equipment Set
23800-85 TrimTalk 900 Rover Equipment Set
TrimTalk 900 Accessories
27608-00 TrimTalk 900 Operation Manual
25962-01 TrimTalk Setup Program version 2.10
Base Station and Repeater Accessories
27544-00 11DB Directional Antenna w/Cable, 900MHZ
21322 50' 4000 Port 1 Base Cable
21323 50' 4000 Port 2 Base Cable
21257 50' Power / IO Extension Cable
22882-00 5DB Whip (and 0DB Tip) with Base
27543-00 9DB Directional Antenna w/Cable, 900MHZ
25945-00 Ant/Adapter Mounting Kit
14283 DB9 to DB25 Adapter
14284 TrimTalk to PC Cable
Rover Antenna Accessories
20297 3' 4000 Port 1 Cable
21109 3' 4000 Port 2 Cable
27524-00 5DB and 0DB Mobile Antenna w/Mag Mount
23031-00 Rover Antenna
27525-00 Rover Antenna w/Adapter (5DB Whip & 0DB Tip)
Power Supply Option
13542-00 10 AH Battery / Case / Cable
13543-00 6 AH Battery / Case / Cable
17466 Camcorder Battery
18542 Camcorder Battery Cable (Single Head)
21349-00 Camcorder Pack
23001-00 Office Support Module II (OSMII)
Posted : July 29, 2012 11:59 am
(@dane-ince)
Thanks Robert,that'll work
I appreciate the help very much
Posted : July 29, 2012 12:35 pm
(@big-al)
Dane,
Did you ever find a copy of the 900 manual?
Al
Posted : December 25, 2012 7:11 pm
(@ridge)
I think I have a couple of the manuals along with a set of three radios that I have never used (part of a deal long ago). I don't know why I've never thrown them in the trash but next time they are in hand if the trash can is nearby they're gone. Should anyone want them and be willing to pay the shipping they can have em.
Posted : December 25, 2012 10:12 pm
(@big-al)
I put mine on eBay a few months ago, and while they didn't fetch much, they did fetch something. I'd be grateful if you'd send me a copy of that manual, though, and I'll pay postage.
Posted : December 26, 2012 3:41 am
(@clubalhambra)
Do you still have your radios? Sure would like to save them from the trash if you do. Thanks - Peter
Posted : June 22, 2013 9:14 am
