Trimble Survey controller Alignments
(@sir-veysalot)
I have an alignment of PI's with no curves. Points 500 to 550. Starting station at
#500 is 0+00. Is there an easy way to input this data into the controller? It would be nice to only have to input the starting point and station, and then just list the remaining point range (501-550). Can it be that easy?
Posted : January 29, 2013 7:13 am
 jaro
(@jaro)
Go to "Key In"
Go to "Alignments"
In the top box enter "500-550"
that is assuming those points are in the data collector.
It will assume the beginning station is 0+00.
If you needed a different starting station, you can store the alignment and then go to "key in" then "roads", select your alignment, edit horizontal alignment, edit start point.
500-550 will give you every point between, 500,550 will give you a straight line between those two points.
James
Posted : January 29, 2013 9:22 am
(@ralph-perez)
> Go to "Key In"
> Go to "Alignments"
> James
:good:
Posted : January 29, 2013 11:39 am
(@sir-veysalot)
Thanks!
Posted : January 29, 2013 12:49 pm
 vern
(@vern)
Yep what they said. Don't expect Trimble to create any curves though.
Posted : January 29, 2013 6:34 pm
