Trimble S6 Robot 2.4 ghz Radio Connection Issue
2 Users
lpaclon
(@lpaclon)
Wondering if anyone could point me in the right direction here.
Trimble S5 Robot with onboard 2.4 ghz radio and same on the Spectra Ranger3 data collector.
When we get out to about 300' we lose radio signal.?ÿ We have replaced antennas on both ends.?ÿ The dealer cannot replicate the problem and the only suggestion is to start replacing parts to troubleshot/fix.
Has anyone else had similar issues??ÿ Any known weak spots in this setup??ÿ
Posted : January 29, 2021 12:50 pm
stephen-ward
(@stephen-ward)
If it's site specific then I would be looking at interference.?ÿ There was an issue awhile back where turning off WIFI cleared up problems with the 2.4 ghz radios.?ÿ Otherwise I'd suspect one of the radio modules is failing.
Posted : January 29, 2021 2:30 pm
stephen-ward
(@stephen-ward)
Also, sometimes if you've upgraded software or drivers on one device but not the other, you can get a situation where things are not compatible.
Posted : January 29, 2021 2:32 pm
