Trimble R10 question
8 Users
Skeeter1996
(@skeeter1996)
How do you ignore the Tilt sensor calibration? It doesn't usually work right anyway. My rod bubble has been calibrated and I trust it more than the ebubble.
Posted : June 9, 2021 4:21 pm
stlsurveyor
(@stlsurveyor)
Just turn it off. You do not have to use it or have it turned on.
N10,000, E7,000, Z100.00
PLS - IL, MO, AR, KS, MN, KY
Posted : June 9, 2021 5:17 pm
Skeeter1996
(@skeeter1996)
How do you get by the tilt calibration routine?
Posted : June 9, 2021 6:15 pm
stephen-ward
(@stephen-ward)
@skeeter1996 In Access under your RTK survey style in the Rover Options there should be a box that says "tilt functions" or "tilt" or similar.?ÿ Just uncheck that box to disable the tilt functions.
Posted : June 9, 2021 7:09 pm
jitterboogie
(@jitterboogie)
Do all the calibration routines. Esp the one on the tripod where you spin it.
Calibration of the e bubble to your 8 minute already rod calibrated bubble makes for pretty tight work with good skies.
Or just turn it off like the other replies.
Get an R 8 if you don't want the tilt.?ÿ Its less expensive, and works great.
Posted : June 9, 2021 10:35 pm
rover83
(@rover83)
Posted by: @jitterboogie
Or an R12i if you don't want to have to worry about it at all. ????ÿ
Posted : June 9, 2021 10:41 pm
stephen-ward
(@stephen-ward)
@rover83 I've been torturing the ones I just got a couple of weeks ago.?ÿ My favorite party trick is to stake a control point, then shoot it as a topo point and wave the rod in giant circles for a minute or so and then store the shot and watch the mouths drop when the shot is within .01' of the control point.
Posted : June 9, 2021 11:38 pm
Skeeter1996
(@skeeter1996)
I just want to be able to use it instead of standing there slowly turning the receiver trying to get past the "Calibration Failed" so I can get some work done.
Posted : June 10, 2021 2:17 am
jitterboogie
(@jitterboogie)
@rover83
Bragger ????ÿ
Not jealous here at all, hopefully optimistic that's all.
Posted : June 10, 2021 5:57 am
lee-d
(@lee-d)
You only really need to do the first calibration, which is the accelerometers that determine the amount of tilt. All it requires is a good setup and it probably takes 30 seconds. I do it on a tripod with a tribrach and rotatable adapter - after performing the calibration I rotate the adapter and make sure it stays level. This gives me the added benefit of confirming that my tribrach is still in good calibration. It's pretty unlikely that your pole's level is more accurate than the ebubble when the calibration is performed correctly.
The other two calibrations are for the magnetometers, which as far as I can tell are mainly used for compensated points, which I've never had much success with. So I don't usually bother with them.
Posted : June 10, 2021 6:39 am
allen-wrench
(@allen-wrench)
@rover83 Is the R12i self-calibrating?
Posted : June 10, 2021 7:30 am
jimcox
(@jimcox)
Posted by: @rover83
You forgot to mention the non-optional TSC7 or 5 accessory available at extra cost
Posted : June 10, 2021 12:44 pm
