Trackability of Seco (6405-12) Nodal Point Mini Prism by Leica Robotics Total Station
(@amdomag)
I am considering to buy a handy mini prism for stakeout work. What I have in mind is the Seco (6405-12) Nodal Point but not sure of its trackability when used with a Leica robot. Any experience? Thank you.
Posted : 15/11/2019 7:35 pm
(@sergeant-schultz)
When I got my first robot, I felt that I wouldn't need to spend the money for a 360?ø glass.?ÿ Well, it's just about impossible to keep a single retroreflector pointed constantly at the instrument.?ÿ Turn away even for a few seconds, and lock is lost and time is wasted reorienting the target and waiting for the instrument to reacquire the target.?ÿ
I have a couple of mini prisms similar to the Seco (6405-12), but prefer one like this: New  360 degree Mini Prism  for Surveying  Total Stations for stakeout.?ÿ Fairly close tolerances can be met by using care in orienting the prism.
Posted : 16/11/2019 3:26 am
(@amdomag)
@sergeant-schultz
Is this a seco glass?
Posted : 16/11/2019 3:33 am
(@party-chef)
Using single prism with tracking is a pain and your precision will suffer.
I would rather spend it on gear than on wages for some poor guy struggling to get the job done with the wrong equipment.
Posted : 16/11/2019 3:50 am
(@amdomag)
Any experience of the trackability of Seco 360 deg. prism (6401-00-YEL)? As it is a Seco product, I would think it is of good quality and cheaper than Leica 360 deg prism as well. The prism design as an array/assembly of 6 individual glasses provides a feeling that there would be dead spot(s) around the prism.
Posted : 16/11/2019 5:08 am
Posted by: @party-chef
I don't understand why you think precision will suffer.?ÿ I use a miniprism exclusively with my robot, and don't have any precision (or accuracy!) problems.
Posted : 16/11/2019 8:51 am
(@amdomag)
@jim-frame
Are you using standard or 360deg mini prism?
Posted : 16/11/2019 9:25 am
(@party-chef)
@jim-frame
If I recall correctly you use Leica -17.5 mini prisms, when you use standard mini prisms robotically the error from pointing of the prism creeps up pretty quickly.
Are you working alone without a 360 prism? I thought you were the user that touted the higher precision lighter weight 360 Leica glass.
True precision aside I have found that working alone with tracking to a standard, moving prism to be an awkward proposition leading to second best results. That loss is what I was trying to speak to, more than say genuine centering error.
Posted : 16/11/2019 11:00 am
Posted by: @amdomag
Standard GMP-101.?ÿ When I started out with a Leica robot I tried using the big 360 glass, but soon got tired of the weight and size and the need to make sure I had one of the yellow arrows pointed at the gun when taking control shots.?ÿ The GMP-101 has a tighter pointing error specification, and it's easy to tell when it's pointed correctly.?ÿ I do lose lock a lot when doing urban topo, but that happened with the 360 as well, and PowerSearch (I forget what GeoMax, which I now use, calls it) allows me to regain lock pretty quickly.
The mini-360 has too short an ATR radius for my needs, so I never bought one.
Posted : 16/11/2019 6:28 pm
Trying to wrap my head around this.?ÿ The advertisement calls it a 25mm o/s prism,?ÿ the backplate states it is a -17.5mm prism, which should equate to
a 16.9mm o/s in Leica-speak.?ÿ Which one is it ?
Screen Shot 2019 11 16 at 9.24.50 PM
Posted : 16/11/2019 7:29 pm
(@amdomag)
@jim-frame
Thanks for the input, Jim. I am currently using GRZ122 and GRZ4 Leica glass. Yes, they are big and heavy.
Posted : 17/11/2019 5:03 am
The 25 mm would be the diameter, not an offset.
Posted : 17/11/2019 5:48 am
@bill93
ugh.  Thanks, Bill
Posted : 17/11/2019 6:30 am
