Topcon total station at something other than 1200 baud?
5 Users
Lance Andre
(@lance-andre)
Can you reconfigure a Topcon total station to operate at something other than 1200 baud? If so how?
I have a Parani SD1000 BT adapter which I'm trying to link up to one and the lowest baud rate (understandably) is 2400 baud. But everywhere I look it appears the Topcon Total station only runs at 1200 baud.
Thanks for the help, Lance
Posted : August 7, 2013 3:49 pm
djames
(@djames)
Most newer topcons will allow 9600 baud, should fined it in the topcon com setup for rs232
Posted : August 7, 2013 4:18 pm
shawn-billings
(@shawn-billings)
I think you can configure the paranis to 1200 using the configuration software instead of the dip switches. Older topcons are fixed at 1200 as far as I know and 7 bit parity (and I can't remember if it's even or odd of the top of my head, but I think it's opposite whatever standard convention is).
Posted : August 7, 2013 4:21 pm
7 E None (data bits, parity, stop bits, respectively).
Posted : August 7, 2013 5:20 pm
shawn-billings
(@shawn-billings)
:good:
Posted : August 7, 2013 5:31 pm
Scott McLain
(@scott-mclain)
Lance,
Is that an older Topcon? If Jim is right, and he usually is, than it will not work. To quote the manual
Parani-SD1000 supports only 8 data bit. In the case of 7 data bit and even/odd parity, use SD 8 data
bit and none parity. At this time, master and slave are Parani-SD, Parani-ESD or Parani-MSP series.
But 7 data bit and none parity is not support.
Did you try S/W setting?
SD 1000 Manual
Scott
Posted : August 7, 2013 7:14 pm
Lance Andre
(@lance-andre)
Thanks on the Manual link, I did find that I can override the dip settings and get 1200 baud using the software program... the 7 data bits, is the next challenge...
Posted : August 7, 2013 7:49 pm
