Topcon Tools antenna list blank
2 Users
(@jimmy-cleveland)
I ran a quick static session this morning, occupying some points I had on an old job I did, and had OPUS values on for horizontal, and City Benchmark values on for vertical.
I import the static sessions into Topcon Tools, and the antenna pull down menu on each line is blank, and does not populate with my normal list. The antennas I need are the OPUS X90D, and the Topcon Hiper V Units.
I can open other jobs, and the list is there. It looks like something is happening when I import the files, and the antenna list is erased for some reason. I have had this happen once before, but I cannot remember what fixed it.
Any suggestions? I will be stepping away from the computer for a few hours, but will be back shortly.
Thank you in advance,
Jimmy
Posted : September 23, 2016 11:16 am
(@jimmy-cleveland)
bump....
Any ideas? I can open older jobs and the dropdown menu has the antennas listed. I can run the program at home on my laptop, and it works fine. It seems like it is this windows 10 desktop maybe causing an issue. This problem just started last week. I seem to remember it happening once before. If I can figure it out this time, I will definitely write down the fix.
Posted : September 27, 2016 12:57 pm
(@leegreen)
Windows may have lost path to the settings folder. Look for the folder on old PC, and verify it exists on the other.
BTW. I upgraded to Magnet Tools several years ago. Never looked back.
Posted : September 27, 2016 3:46 pm
(@jimmy-cleveland)
Lee,
Any idea where the settings folder is? I looked in the App Data folder under the Users>Jimmy>, and did not see anything, I did find a bunch of files under the Program Files (x86)>Topcon
I will take this laptop to the office tomorrow, in case I have ot process on this laptop. I did not check my field laptop today, to see if it worked. I actually forgot it was at the office.
Thanks!
Posted : September 27, 2016 5:43 pm
(@leegreen)
I don't remember. But a lot of software stores setting under the C:UsersYour_Login_NameAppData
Posted : September 28, 2016 4:05 am
(@jimmy-cleveland)
thanks!
Posted : September 28, 2016 4:45 am
