I have a GPT-8005 robot that I run with a recon with survey pro 4.5.3. I also have ranger with survey pro 3.8.3 with robotics that I use with my conv. TS. Well the recon had to go to the shop the other day for repair. No big deal right, I'll use the ranger. Wrong my ranger does not support my reflectorless robot. I have looked for the 4.5.3 (last TDS version before Spectra release)download but with no luck. Does anyone know where I can find this update? Thanks
just put it on GTS not GPT... the drivers should be the same.
It does work like that, but cannot collect reflectorless shots.
Dan,
I have the same instrument, and an older version of TDS on my Ranger 200T, not sure which version, but pretty close to what you are using.I have to switch the instrument to reflectorless at the gun, and not with the data collector.
Works fine when I do that.
My newer Ranger has the newer version that has the target manager on it, and it is pretty nice.
Jimmy
The update from 3.x to 4.x is not a free update. I do not recall the cost off the top of my head. Your dealer should be able to get you a copy of the installer.
I have SP 4.6 i think and have to do the same thing as Jimmy said w/ my 3000. Works fine with my Nivo but will not switch the Topcon to non-prism.
