Trimble Business Center — From point cloud to plan sheet. Start free trial.
TBC custom reports
jonsurvey
(@jonsurvey)
Hi all, longtime follower, first time poster today. I need some help creating a report within TBC. Basically i want to have an as-staked report with another column to add an inverse between the design point and a check shot that isn't an as-staked point, just a regular topo point.
So it would be a typical as-staked report with difference from design to as-staked AND one from design to a separate measured shot.
Is this possible? Thanks!
Posted : April 18, 2018 10:50 am
guy-townes
(@guy-townes)
I'm curious about this as well as we have a contractor that is requesting stakeout reports on a large project we are doing this summer. We have TBC as well.
Several years ago I worked for a company that provided stakeout reports but we were using Survey Pro and a program call foresight. I believe that if you took a shot on the hub in the stakeout mode?ÿNOT in the regular sideshot screen?ÿit produced the report with deltas. Maybe someone can confirm?
Posted : April 18, 2018 2:46 pm
mgillis
(@mgillis)
Have you tried Point Comparison Report??ÿ You can set your search parameters and tolerances for anything you would like to flag in the report. The report looks like the attached screenshot.
Posted : April 19, 2018 8:28 am
jonsurvey
(@jonsurvey)
That looks perfect! I just can't figure out how to make TBC use that as a report. I've downloaded the xls file, saved it. But TBC seems to always want a word file. Is there an easy way within tbc to generate this report?
Thanks!
Posted : April 23, 2018 11:25 am
mgillis
(@mgillis)
It is under the reports tab then more reports, I am running TBC ver 4.00.
Posted : April 23, 2018 4:51 pm
Ancient Kudurru stone artifact related to land surveying history.
