I am trying to figure grades for DI boxes that are on a road in a vertical curve. I have set up an alignment in my collector. I am wondering how I can tell the collector to show me the grade of the alignment at a certain station.
Seems like this should be simple to do, but I appear to be having one of those mornings.
Use the parabolic curve layout function under the curve menu.
First question
Did you define the vertical alignment? Did you define the cross sections? Then create a road. Once you do that it should spit out everything for you
Don't have my Nomad in front of me, but I believe it can be done ion the cogo menu. I know you can create control points from stations and offsets and it will give a a point with NEZ. As soon as I get to my recon/nomad I'll see what the sequence is.
Ralph
Stake out offset. You will need to set the instrument to manual if not connected to instrument, and set up a fake back sight. Then put in station and offset you want t and compute, it will out put the angle, distance and elevation of point needed. Jp
I love seeing the different ways we all get to the same end.
Thanks Guys!
First question
I put it in as an alignment only...did not set up a road file. Therefore, I have no cross sections to work with.
Thanks JP, I recall doing it with out being in manual mode. I might be offest stake in cogo or offset menu.
Ralph
Yes, I still have an old hp 95 with survey pro loaded and it had a program called grade book that worked real good for checking that your alignments fit with the plan set. I don't see that program in the newer data collectors. Jp
