I was wondering if someone could convert a *.survey file for this version of Survey Pro to a FBK file format for me.?ÿ The release notes for Survey Pro indicate that Style Sheet Viewer 1.17 should work for converting my *.survey file to a FBK file format.?ÿ However, it did not work.
Thanks!
Posted : October 23, 2021 10:24 am
If you have survey pro in a DC you should be able to go to Job, view report then use the FBK file template. It should generate the report then choose to save it. This will save as a FBK file.?ÿ
Posted : October 25, 2021 6:58 am
