Survey Pro 5.3 Subdivide an area
2 Users
(@your-other-right-2)
Has anybody been able to figure out how to use this function? it keeps asking me for a bearing to use when using the Hinge method. When i use this function in cad, etc... i do not have to define the bearing. i do not want to define the bearing, just the point where the intersection will make the lot the specified acreage.
Thank you,
Posted : May 5, 2014 1:17 pm
(@harold)
I believe that the bearing it is asking for is the bearing leaving the last point that the line coming from the hinge point will intersect. I have survey pro, and I have used this function a few times. I cannot remember the exact steps. I will check back later and be more definitive.:-$
Posted : May 5, 2014 6:02 pm
