Survey Pro 5.1 + GPS Calibration
(@stlsurveyor)
Does anyone know how to, or if it is possible, to export the GPS calibration file from Survey Pro software? I have downloaded the file (.job) into TBC-HCE with the attempt to export the calibration file (.cal) to use for grade control systems. Is this possible?
I am running the free version of TBC-HCE.
Ryan
Posted : July 25, 2013 2:34 am
(@kevin-samuel)
I don't know how to export/import the localization from Survey Pro to TBC. However you should be able to view the parameters of the localization/projection in Survey Pro and then manually key those same parameters into TBC.
Hope that helps, good luck.
Posted : July 25, 2013 9:20 am
(@jp7191)
I think you need an add-on to the data collector software (trimble extension) to import gps data into tbc? That was how it was back in version 4.7.1. I agree with Kevin you can key in the parameters. Jp
Posted : July 25, 2013 9:35 am
