Hope someone can help, I have bought a second hand SRX3 but am unable to get into the memory, I can manually store coords in it but am unable to transfer anything to the internal memory using a usb lead, It connects to my pc and I can see all the programs etc but nowhere to load my SDR data files, Im not sure if I am using the correct file format??. I do have all the bits for the robotic side and this works fine, but want to be able to use it as a traditional EDM.
Thanks in advance, Andy..
Are you using the SDR software?
Have you checked that your com setting file is set to YES? Had that problem when I first got my station.
Thats sorted it thanks, Ive spent days trying to work that one out!:-)
Cheers enjoy your SRX. Just be careful of rain or water splashes. Always had a problem where moisture would eventually seep into the touch screen and corrode the circuit board. Apparently it is a design flaw according to my dealer.
