Hi. Recently I purchased sena Perani sd 1000 bluetooth adapters and I like them because of the size but I want to use them with topcon 8003. Rebotic total station its working but RC2B is not working with them if any body knows the perametrs i appreciate thanks
Give more info .. Explain what you done at both ends data collector and instrument...
The parani radios work well. With 5dbi aerials they will reach 500m and further with good conditions. Set the GTS to 9600,8,n,1. goto programs Page2 , press F4 external link. Press F2 settings. Goto 1 set CABLE. Goto 2 set 9600, 8, 1, n. ETX, Hi, RecB. must use rec B.
Set your data recorder to cable, com1 and set 9600,8,n,1. Pair the parani in standard mode default 9600,8,n,1. Plug into data recorder com port. Plug in the other to the GTS com cable, connect to port. You must be in external link to comunicate under Ext Link press 1.
The parani act as a long cable to communicate with the data recorder.
RC not working interns of search function when you fire it on the data collector? Do you connect to the RC with Bluetooth or cable.
No I want to use rc2 like a remote no connect with data colector only for turning the gun
RC has nothing to do with the paranis . RC communicates with the special handle on the gun ,
I'm using a Topcon GPT 8203A. I paired the parani adapters, unplugged the satel radios, plugged in the paranis and went to work. I never had to change any settings.
Do you have a "null modem adapter" on the gun cable end?
I am using the pin male cable not nill modem adapter
I am not using the null adapter
hi is your RC2 WORKING WHEN YOU USEING THE SENA PARENI BLUETOOTH ADAPTERS
Try one. My parani came with one and I am using an older Topcon.
Are you u useing the Rc2 and parani blue tooth adapters together
No. At the bottom of this thread is a couple pictures of my setup. The Gun and DC think that they are plugged together with cord. The orange thing on the cable is the Null Modem. Will not work without it.
[msg=176260]Old Post pictures at bottom.[/msg]
The RC2 works exactly the same as when we were using the Satel radios up to about 2,200'. Farther than that distance we had to control the robot with the arrow keys. I went as far as I could go (which was 5,340') and was still able to control the robot and take shots using the parani.
I am using the same cable that came with the robot that plugs in at the gun and into the satel radio. No gender changer or null modem adapter needed. If I use a standard data collector cable I have to use a null modem gender changer.
NOMEE
Did you get this resolved. I just came across the same problem
