reflectorless in auto pick up mode
 RADU
(@radu)
Has any one used a leica 1100,1200 or viva reflectorless to auto pick up say a quarry wall so it records points at say 1 m grid intervals?
Want to know coverage range and spread from instrument , optimum distance of TS from face . and Time it takes to locate an area.
Thanks in advance
You can email me if you have some literature or a pdf file on matter.
RADU
Posted : June 14, 2012 2:16 pm
 CSS
(@css)
Yep.
I'd use a laser scanner. 😀
It's slow. Count the number of points you're looking at and estimate around 5 - 10 sec per shot.
You need to use reference plane (that is the software with the grid points option).
The instrument will shoot everything in the area you select. Range will be as good as whatever your reflectorless can do normally.
Posted : June 14, 2012 6:03 pm
 RADU
(@radu)
Of course you would use a scanner ...LOL Have U got plenty of work for it?
RADU
Posted : June 14, 2012 8:59 pm
 CSS
(@css)
Yeah it's doing pretty well. Even without being able to spend time marketing or nailing down our procedures I think we're getting up towards 30% of our work being scanning.
Posted : June 14, 2012 9:45 pm
(@tom-bushelman)
I'm not familiar with Leica software but my S-6 with TDS software has a scanning mode. You can set paremeters for whatever you need, I would use every 3 feet instead of 1 meter on this continent and it takes about 1-3 seconds per shot. Certainly not scanner speed but way better than hanging from a rope from the top taking shots with a prism.
Posted : June 15, 2012 4:23 am
(@georges)
I am curious, what were your last five scanning projects and over what extent of time (example: 5 projects / 3 months)?
Posted : June 15, 2012 4:54 am
(@sae-wa)
I have used the Leica Viva TS 15 with very good success on several projects. One example was a rock slide about 600'x600'. We were asked to get shots every two feet. The autoscan program is not standard but well worth the money. Much cheaper than a scanner. The biggest problem was filling in the shadow areas behind big rocks.
Posted : June 15, 2012 6:17 am
 CSS
(@css)
Ok, from the start of the year, 6 out of 15 projects have used the laser scanner, most for mining work.
(only 15 projects so far. We don't do that many projects each year.)
Posted : June 16, 2012 5:55 am
We just added a Leica C10 scanner and I could see carrying that thing around and using it for regular topo. It is in a smaller box and there are a lot fewer accessories such as huge batteries and it can be operated with the on-board software. It can also be run from a smart phone using a remote desktop but all the data still gets stored on the scanner.
We still have the ScanStation 2 (hope to replace it next year). The SS2 requires carrying around a much larger volume of stuff.
There are long range scanners intended for mining pit work.
Posted : June 16, 2012 6:00 am
(@georges)
Mining is a good industry for scanners. Its cost remains relatively small compare to the rest of mining assets.
The right technology for month-end survey of pit walls.
Posted : June 16, 2012 7:48 am
 CSS
(@css)
We also use Reigl VZ1000 and Z620's when required.
Posted : June 16, 2012 2:53 pm
 CSS
(@css)
However, the C10 has a nice advantage that the long range scanners don't. It can be setup level, which means less control required and/or less need for heavy overlap of scans.
I much prefer the C10, even with it's shorter range.
Posted : June 16, 2012 2:56 pm
