Strictly Surveying
1
Posts
1
Users
0
Reactions
3
Views
Thinking like a builder rather than a surveyor, why would you need to carry the grids through the building if the shell is already there? I could understand the need for a new build with structural elements but since that's not the case, wouldn't resecting of the building walls/corners work? You're essentially trying to fit everything into the existing floorspace and with the building moving around as you get higher, sticking to the same control network seems counterproductive.?ÿ
Posted : February 4, 2023 2:05 am
