Emmanuel, post: 433738, member: 12658 wrote: hi do you have the winflash supervisor mode installer? or do you know how to create a .set file for R8s, R10 and trimmark 3 to update/change preset RF on these devices.
I don't. The newest Trimble receiver I own is a 4700. Most of mine are older.
Happy to be in Europe. I just switch on my rtk-gps, make the ntrip connection and am ready to go. You guys carry frequency scanners, radio links, base stations, magnetic locators, ...
We just carry a shovel:-)
Emmanuel, post: 433724, member: 12658 wrote: pre saan ka nagpa program ng Frequency mo? gamit ko R8s at R10 tapos yong Trimmark 3 ko sa US ko binili online ngayon di sila pareho ng Frequency. mao nay problema naku kay dili maka connect ang R10 rover naku.
Kumusta bai? Ininglis lang sa ta para dili lain tan-awon sa uban. Hehehe.. Anyway, this post was originally way back in 2012 I guess. At that time, I don't have the programming cable. I purchased the programming cable a few months later and now I can do what I want. I do my own programming letting GNSS from different models to see each other. I have my Leica GS09 and GS14 see each other. Given this capability, I can scale up my GNSS teams as I wish.
I also purchased a frequency scanner to help me readily identify the cleanest channel then proceed from there. It is very handy.
Regards.
Jim Frame, post: 433737, member: 10 wrote: If you have a Javad Triumph-LS, the scanner is built in.
This is great!
amdomag, post: 433872, member: 1683 wrote: Kumusta bai? Ininglis lang sa ta para dili lain tan-awon sa uban. Hehehe.. Anyway, this post was originally way back in 2012 I guess. At that time, I don't have the programming cable. I purchased the programming cable a few months later and now I can do what I want. I do my own programming letting GNSS from different models to see each other. I have my Leica GS09 and GS14 see each other. Given this capability, I can scale up my GNSS teams as I wish.
Regards.
yes.. i do have the cable to communicate for all the devices but trimble products only authorized dealer to change RF on radios. now my problem is my R8s and R10 both have the same RF which is within 430-456mhz but they can go up to 470 but, my Trimmark 3 external radio which i bought from the US is setup from 460-467mhz which has a range of 450-470mhz. meaning, i can't step-down my external radio rather i need to step-up my base and rover. the issue is at the base i can add RF but cannot be used for transmitting correction because it only allows me to use the preset RF on the R8s.
furthermore, as i read from other comments i can changed the RF for all of them if i have the winflash supervisor version which i hope somebody here can help me by sending me a copy of that software.
