Proposed rule change for Washington State (WAC = Washington Administrative Code) to govern content of Topographic Mapping by registrants. I wondered if any of you had any comments? There are currently no rules in Washington governing content of topo surveys.
WAC 332-130-145 Topographic map requirements. The following requirements shall apply to topographic mapping surveys performed by individuals licensed under chapters 18.43, 18.96, and 18.210 RCW. Such requirements should be considered minimum only. The professional conducting the work will determine what precision and accuracy are expected to be utilized for topographic mapping services necessitating various levels of accuracy. Negotiation, requests, and contractual requirements with clients, jurisdictions or other professionals will determine the specifics and quality of the vertical information provided.
The following elements shall be included on every survey map that has topographic information.
[INDENT](1) Graphic information:
[INDENT](a) North arrow;
(b) Scale bar;
(c) Legend of symbols used;
(d) Company and licensee contact information;
(e) Seal and signature of licensee.
[/INDENT]
(2) Statements of clarification of vertical information shown on mapping.
[INDENT](a) Vertical datum used;
(b) Purpose or intended use of topographic mapping (if relevant);
(c) Basis of elevations citing benchmark(s) used with elevation(s);
(d) Source of contours;
(e) Sufficient labeling to determine contour interval(s);
(f) Project bench marks established (if any);
(g) Statement of elevations and contour accuracy.
[/INDENT]
(3) Boundary information (if shown).
[INDENT](a) Source of the boundary information as required by WAC 196-23-020 (3)(c) if map is not prepared by a professional land surveyor;
(b) A record of survey prepared by a professional land surveyor is required if monuments are set per chapter 58.09 RCW;
(c) Survey map requirements as listed in WAC 332-130-050.
[/INDENT]
(4) Underground utilities information (if shown).
[INDENT](a) Source of surface markings (if any);
(b) Statement of accuracy of utility line depiction;
(c) Notification if utility line not exposed or marked for location purposes;
(d) Statement of underground utility depiction purpose and limitations of use.[/INDENT][/INDENT]
I find it a sad state of affairs that there is a need to legislate what is shown on a map. These elements may be focused for engineers and drain field designers who are now licensed to do this work but perhaps we need help too.
This morning I took a quick look at plans for two public works projects in my neighborhood. One has no benchmark, datum or basis of bearings and the other project is not tied to any of the monuments shown or lot corners set. (There is no record of survey) I find that the crap that is accepted by those of us who sign off on these drawings probably necessitates these guidelines. But will we use them? Who will enforce them?
I am doing battle with a PE who wants to add a one-foot riser to a case where the monument is already down a foot. How long is your arm?
Daniel Ralph, post: 444106, member: 8817 wrote: I find it a sad state of affairs that there is a need to legislate what is shown on a map.
This isn't legislation. It's regulation. But that's splitting hairs.
A lot of states have such minimum standards written into their regulations. Oklahoma does, for example. Neither Washington nor Oregon do.
Mark Mayer, post: 444089, member: 424 wrote: (4) Underground utilities information (if shown).
This is the weakest of the 4 IMO. Statement of accuracy of utility line depiction? If you want me to quote the ASCE Standard 38-02 Quality Level designation then lets say that. Statement of underground utility depiction purpose and limitations of use? I'm not sure I understand what that is supposed to mean. (I do topo's and construction for the money and boundaries for the love. There is no money in boundaries).
My biggest gripe is specifying it only applies to licensees. Everyone has gone chicken $hit since North Carolina.
thebionicman, post: 444121, member: 8136 wrote: My biggest gripe is specifying it only applies to licensees. Everyone has gone chicken $hit since North Carolina.
What happened in North Carolina? Curious.
that is close to being an ATLA level topo
Perhaps the regulations should address how electronic topos are to be accompanied by a stamped and sealed surveyor's report. The draft regulation appears to be more in line with addressing paper mapping.
clearcut, post: 444129, member: 297 wrote: Perhaps the regulations should address how electronic topos are to be accompanied by a stamped and sealed surveyor's report. The draft regulation appears to be more in line with addressing paper mapping.
Great point! Of thousands of acres of topo we do and contract every year, we almost never turn out a paper product.
Mark Mayer, post: 444089, member: 424 wrote: (3) Boundary information (if shown).
Item (C) turns any topo that shows a boundary line into a Record of Survey. Which means, among other things, it has to be done on an 18" x 24" sheet. With a 2" margin on the left side. With a Surveyor's Certificate and an Auditor's Certificate, etc. etc. Seriously?
FrozenNorth, post: 444124, member: 10219 wrote: What happened in North Carolina? Curious.
The NC Dentistry Board tried to regulate whitening teeth. They lacked statutory authority and had Board structure issues. They got slapped hard. Boards across the country are reacting to the (poorly worded) headlines and changing policies accordingly. Few (if any) of the changes are supported by the decision. The elected officials making them are either too lazy to or can't read.
That's the nutshell version...
Mark Mayer, post: 444089, member: 424 wrote: (b) Purpose or intended use of topographic mapping (if relevant);
That requirement would bring out my inner smart-ass: "the purpose of this topographic survey is to depict the elevation, slope, and orientation of terrain features in a graphic and/or digital manner".
James Fleming, post: 444135, member: 136 wrote: That requirement would bring out my inner smart-ass: "the purpose of this topographic survey is to depict the elevation, slope, and orientation of terrain features in a graphic and/or digital manner".
My inner smart-ass would be more along the lines of:
"Purpose is to provide accurate detailed mapping for use by some pimple-faced engineer to create an unusable and highly incompetent set of improvement plans in need of being re-designed by the poor soul chosen to be the construction staking field surveyor."
More seriously, the "if relevant" bit renders the clause meaningless.
Mark Mayer, post: 444132, member: 424 wrote: Item (C) turns any topo that shows a boundary line into a Record of Survey. Which means, among other things, it has to be done on an 18" x 24" sheet. With a 2" margin on the left side. With a Surveyor's Certificate and an Auditor's Certificate, etc. etc. Seriously?
Not if it is Preliminary in nature, so state that on the plans
