Pipe Deformation
Here's the profile of the culvert we shot the other [msg=198683]day.[/msg]
Vert. is 10X
Posted : March 26, 2013 6:12 pm
(@hub-tack)
I would like to know if there is any width variation at the small radius just above the bottom.
Posted : March 26, 2013 6:47 pm
(@andy-bruner)
I surveyed one similar several years ago. It was a reinforced concrete pipe 72" in diameter (to begin with). I am only 5'-8" tall so I should have been able to walk upright down the invert from end to end. I had to duck several inches to be able to walk down the pipe. It should have been a Class 5 (Georgia DOT rating, and probably with imperfect backfill) under 40 feet of fill but the contractor installed a Class 3. We ended up sliding a steel spiral welded pipe through the deformed pipe and pumping grout into the voids. Some loss in capacity but the difference in friction loss mitigated the difference. The best design in the world doesn't work if the contractor doesn't install per the specs.
Andy
Posted : March 27, 2013 2:25 am
Here's a finished plan-profile.
and a close up on the plan view.
The width measurement was taken from side to side at the mid-line joint as seen in this pic.
At the point where water surface and the joint appear the same -7.9' wide on the 7.5' pipe. the joint was underwater.
Posted : March 27, 2013 9:21 am
(@hub-tack)
Thanks Mr. File, I'm thinking two things, lack of compaction below the spring-line and not enough cover.;-)
Posted : March 27, 2013 11:09 am
(@christ-lambrecht)
Thanks for the update!
Chr.
Posted : March 27, 2013 11:22 am
(@andy-bruner)
Looking at the cross section there appears to be PLENTY of cover (35+ feet). Not enough compaction below the spring line perhaps, but I believe that CMP like that would need imperfect backfill at that depth of cover to transfer the loads and avoid crushing the pipe. Now I'm going to have to go dig up my old pipe manuals, I haven't looked at them in years.
Andy
Posted : March 27, 2013 11:32 am
