Ouch == bitten by a bug in Trimble Access
5 Users
jimcox
(@jimcox)
Bugger
Got caught by a subtle bug in Access today.
Adjusting the pole height of a gps observation will change the height for that observation,
But it does not alter the height of an averaged point derived from that observation.
I changed both shots on a control point, but a later resection used the unchanged averaged position
The net effect is that the house foundation is now 400mm too high
Sigh 🙁
Posted : January 17, 2019 9:10 pm
Are you referring to an antenna height that's changed after the observation is recorded, or that all observations to be averaged must be taken with the same antenna height?
Posted : January 17, 2019 10:54 pm
jimcox
(@jimcox)
the former
Posted : January 18, 2019 12:07 am
makerofmaps
(@makerofmaps)
I think that is the case with a lot of the cogo type routines, like point on a plane or distance distance.
Posted : January 18, 2019 11:19 am
Thanks for the heads up!!!
Maybe it's a bit like a stake-out point which won't move once collected.
Posted : January 18, 2019 12:33 pm
christ-lambrecht
(@christ-lambrecht)
Tricky indeed ... but make sense to me when you edit 1 observation where multiple obeservations came into play. However a warning by the software would be very welcome here.
I'm used too checking the final edit results in the point manager where you can review all abservations for the point, or review in the map view with point elevations active in the map display.?ÿ
Jim did you move to access 2018? TSC7 or T10?
Any plans to do so?
regards from Belgium
Christof.
Posted : January 19, 2019 5:26 am
