Trimble Business Center — Know your data is right. Start free trial.
OPUS Error: The data spans more than two days
johnh2005
(@johnh2005)
I am having a problem with a particular file. I send it off and I get this back:
FILE: sherwin3.tps OP1427655214535
1022 The time span of the submitted dataset spans more than two days.
1022 OPUS will only process data taken within two consecutive days
1022 Aborting...
1022
The file was ran just short of 8 hours. I have used tps2rin and looked at the .15o file and I noticed this:
21312916.994 113970002.916 7
3696.296
15 3 27 13 24 30.0000000 3 5
sherwin3_Z7K0_S1 MARKER NAME
0.0000 0.0000 0.0000 ANTENNA: DELTA H/E/N
000 -Unknown- ANT # / TYPE
SE TPS 00000000 COMMENT
*** THIS IS THE START OF A NEW SITE *** COMMENT
15 3 27 13 24 30.0000000 0 15G14G15G18G21G22G24G27R 1R 2R 3R11R12
R17R18R24
Then there are a few more lines after that. However, I think this is where the problem is coming in. The file should have just been ended, not starting a new point. I tried taking that out, then OPUS tells me that the file is corrupt. I am at a loss here and this project is due next week.
If anyone is available to help that would be fantastic! Thank you so much for your time!
Posted : March 29, 2015 2:08 pm
John1Minor2
(@john1minor2)
if the new site comment occurs near the end of the file, you could try using TEQC or WinTEQC to edit.
Posted : March 29, 2015 3:01 pm
johnh2005
(@johnh2005)
I tried using WinTEQC but when I try to open the TPS file (I use Topcon) it just locks the program up and it won't respond. :-$
Posted : March 29, 2015 3:07 pm
Use Topcon tools to split the file at the time of station change. If the two files don't run trim a few seconds off. I have tried to erase tools from my memory (considering g shock treatments) but you may have a 'separate files for different tracks' import option ..
Posted : March 29, 2015 3:12 pm
johnh2005
(@johnh2005)
I have never used Topcon Tools. I will try that when I get back to the office Monday. I got called off the job. Thank you so very much for the help so far!
Posted : March 29, 2015 3:17 pm
John1Minor2
(@john1minor2)
Send me your email address and I can put you in touch with a knowledgeable individual with NGS that has offered his help. He isn't currently a Beer Leg member so ha can't contact you through the Board. He saw your post and contacted me because he and I have worked on a project together in the past. Please contact me soon because I am leaving shortly to go out of town for a few days.
Posted : March 29, 2015 3:59 pm
johnh2005
(@johnh2005)
I can be contacted at [email protected]. Yhank you again.
Posted : March 29, 2015 4:14 pm
John1Minor2
(@john1minor2)
I forwarded an email to you.
Posted : March 29, 2015 4:25 pm
johnh2005
(@johnh2005)
It was resolved. Thank you so very much for all of your help.
Posted : March 30, 2015 5:34 pm
