OPUS Elevations in TBC
2 Users
Byron Sanderson
(@byron-sanderson)
Having a tough time with this one...
I have an OPUS result that I am importing into TBC and I want to use the horizontal and vertical results in my survey. I import the OPUS position into TBC and assign it the Point ID and Feature code of my (soon to be imported) GPS base position. Upon import of field data I am prompted to merge duplicate points and all goes as planned... my GPS field data (+/-300 shots) has horizontally and vertically changed to the OPUS result - as expected.
The issue is that there is also Total Station data in the file that changes horizontally, but not vertically. This data utilizes control that was set with the GPS and I therefore assumed that it would update with the rest of my field data.
I am certain ths is simply a setting in my import options, but I am having trouble finding where this may be. I am hoping that someone has perhaps addressed this issue in the past and can help.
Any help is much appreciated!
Posted : August 22, 2012 4:22 pm
Joe-Nathan
(@joe-nathan)
Are the GRID COORDINATES for the total station control set to something less than survey quality? They should be set to a quality less than that of the opus solution.
Posted : August 22, 2012 4:50 pm
Byron Sanderson
(@byron-sanderson)
Thanks Joe. I will check the settings and try again.
Posted : August 29, 2012 4:18 pm
