@350rocketmike?ÿ
think inside courtyards of multi family housing with shade structures and garbage enclosures.
I'm gearing up to scan it next time it arises?ÿ
I've only gotten the chance to scan my backyard on a Saturday. Need to get some experience with that.?ÿ
@350rocketmike?ÿ
just like riding a bike...you'll be doing wheelies after you've crashed and burned enough.
this isnt as painful for sure
Don't think I saw what software and DC you are using with that new ancient Leica robot?
@350rocketmike?ÿ
captivate current edition
cs20 lte
I had a simulator of captivate that I played with and I actually thought it seemed pretty intuitive, but usually you don't find the most annoying things until you're using something in the real world. I wish I'd gotten the chance to try a captivate demo with the old Leica robot like I did with Carlson survPC, but at this point the only way I'd be switching from Trimble is if I switched jobs which is very unlikely.
The specs on the cs20 look very subpar compared to the tsc7 and even it is slightly slower than the Panasonic fz-m1 tablet I used to use. Still better than the cs15 that would have originally been used with that 1203 though.?ÿ
@350rocketmike I don??t understand why imu is pain to set up. Turn on in survey style. For rover only. Then start your survey style like any other time. Only difference is walk around or rock the pole around as it gains initialization and off to the races. I do turn it off for observed control point method its under gnss function. And it has to re initialize . Just have the led facing you and your rod bubble and dc where all is good. ?ÿI am usually up and running before i get away from the base or truck good.
