Mold in a tribrach
5 Users
(@tazsurveyor)
Trusted Member Registered
Hi All
I am looking for any suggestions to get rid of a bit of mold visible in the optical plummet.
( I searched under mold and mould?ÿ :)?ÿ )
Posted : 02/10/2022 7:48 pm
(@chris-mills)
Honorable Member Registered
If you search under mould you'll find the eyepiece!!
Sorry!
I've had it happen a couple of times and leaving the tribrach indoors in a warm room eventually shifted it, but there was always a slight dirtyness (presumably dead material) there ever more. Only stripping it right down would get rid of that.
Posted : 03/10/2022 12:00 am
(@tazsurveyor)
@chris-mills?ÿ
Thanks Chris. That may be where I end up. I was wondering if there was a majic remedy about.
Posted : 03/10/2022 12:09 am
(@chris-mills)
@tazsurveyor
Wait and see, one might get posted.
Posted : 03/10/2022 12:14 am
(@tazsurveyor)
@chris-mills?ÿ
I was wondering if anybody had tried an ozone generator.
Posted : 03/10/2022 12:22 am
(@chris-mills)
@tazsurveyor?ÿ
Intresting thought - it might work, let's see if somebody posts to say they have tried one.
BUT, it still won't remove the dead detritus left when the mould dies - that'll still need a strip down job. At least you've learnt to dry the gear out thoroughly after use; you won't do it again.
Posted : 03/10/2022 12:29 am
(@party-chef)
Q tip up the bottom side will clear the field of view usually.
Posted : 03/10/2022 5:35 am
Illustrious Member Registered
My mold guy said they use a UV light device to kill mold in duct work. I would imagine that would be a prefect solution for a tribrach. I would do it even if you believe the junk you're seeing is dead mold, to get rid of that will probably take some deconstruction.?ÿ
Posted : 03/10/2022 5:45 am
(@chris-mills)
@party-chef?ÿ
Only if the mould is on the outside of the plumb lens - I'd assumed tazsurveyor had already worked that out and the problem was that mould was still visible (as a result of some damp inside the system).
Posted : 03/10/2022 6:01 am
(@flga-2-2-2-2-2-2-2-2)
Share:
