Mini prism for column lines
13 Users
(@adam-p)
Does anyone use a mini prism set to stake column lines? Iƒ??ve been in the field for 7 years but have only donƒ??t column lines 3 times. Iƒ??m not particularly fast with a plumb bob. Is a mini prism set accurate enough??ÿ
Posted : 16/03/2018 5:52 pm
(@squowse)
Yes it is, what concerns you about the accuracy??ÿ
Posted : 16/03/2018 7:56 pm
(@leegreen)
I use this setup
IMG 20151104 144628778
Posted : 17/03/2018 4:32 am
Almost exclusively.....Leica GMP101 Mini Prism
Posted : 17/03/2018 4:36 am
(@party-chef)
I like the GMP 111, there may be a small step down in centring from the 101 but it has better ergonomics.
Posted : 17/03/2018 6:56 am
I have a knockoff of the GMP 111 with 30mm offset for Sokkia with thread adapter on top of SECO prism pole point 5194-05 and like the style very much.
GMP 111 knockoff with 30mm offset for Sokkia on SECO point
Posted : 17/03/2018 9:44 am
(@party-chef)
The 30 mil o/s ruins it, try tilting the prism when pointed at an instrument that is locked on and watch the distance and elevation swing a few hundreths, no such swing with the 17.5 o/s.
Posted : 17/03/2018 2:14 pm
(@sireath)
Oh I'm curious about your experience with the mini prism with -30mm as when i do controls with target prisms, i do not have such problems with -30mm targets
Posted : 18/03/2018 4:32 pm
(@party-chef)
For control shots the minus 30 is usually to a bigger piece of glass and the distance is farther, for close up tight staking the difference between the nodal center and the pivot point of the prism assembly makes for some slop that would normally be acceptable but if you are shooting for millimeters you want to remove what you can.
It is my opinion that the Leica folks have it right when it comes to prism offsetting and housing while just about everyone else has it wrong, which is weird.
Posted : 18/03/2018 6:32 pm
(@sireath)
thats interesting. Gonna test out that one day, when projects are not so back logged
Posted : 19/03/2018 12:53 am
(@least)
Hi Lee,
Would you mind sharing a video of the Seco Monopod in action please?
I'd like to see how it works.
Thanks
Posted : 22/03/2018 6:20 am
(@florish)
Hi,
When working with columns.. be extremely careful which prism you use when doing any measurement ontop of a column.
Most prisms are fine when used in horizontal plane.. but as soon as you're measuring under steep angles, then you can't use 360prisms.
Greetings,
Floris.
Posted : 23/03/2018 1:46 am
(@ben-davidson)
Posted by: leegreen
I use this setup
Hello, LeeGreen
Where can I get a monopod like that? The only one that I see is for use with the seco 6000 miniprism and it attaches to the top of that prism. I would like one like in the picture to use with my sliding mini prism seco kit that I have. I assume the clamp is not small enough on the mini poles, but I bet I could glue some rubber inside of it to make the diameter smaller to fit.
Posted : 05/07/2018 7:41 pm
(@leegreen)
It is a combination of the Seco 6000 with a RAM Ball mount to standard 1 1/4" prism pole. I have 3d printed plastic adapters to make the pole clamp fit the small diameter slide prism pole.
Posted : 06/07/2018 12:59 am
(@ben-davidson)
Posted by: leegreen
where could I get the ram ball mount?
Did you make the plastic adapters yourself?
Posted : 06/07/2018 4:08 am
