micro survey field genius 9 works with what total stations
Dane Mince
(@danemince)
Who uses field genius 9 and what total station do you use it with? I am looking to see if their are older leica instrument that will work robotically with this software. I do need reflectorless as well. thanks for your help
Posted : June 16, 2017 9:30 pm
mccracker
(@mccracker)
We just upgraded to FieldGenius 9.1 and I am currently working with a Leica TS02, manual total station. Seems that if the instrument uses Bluetooth you should have no problem connecting as long as you use the correct baud rate and other settings. It would probably help if you posted which instrument you are using so that others could help you more specifically.
Posted : June 16, 2017 9:43 pm
Dane Mince
(@danemince)
I am looking to purchase and that prompts my question
Posted : June 16, 2017 11:40 pm
squowse
(@squowse)
Dane Mince, post: 432992, member: 296 wrote: I am looking to purchase and that prompts my question
http://hardware.microsurvey.com/?prod=fg
looks like 1100 and 1200 series robotics are supported
Posted : June 17, 2017 3:12 am
Dane Mince
(@danemince)
Yeah I know about that list. That list indicates a couple of Trimble products that are not supported. but look like they are supported I already made the mistake of purchasing the software to go with my equipment and now it looks like I will have to buy a total station to go with my software. Perhaps I won't be able to avoid further errors.....
Posted : June 17, 2017 9:45 am
james-w-johnston
(@james-w-johnston)
James from MicroSurvey Support here,
We have since retired the older Trimble driver, it worked but in a very limited fashion. Lots of people are working well with Leica 1100 and 1200 instruments, robotic and otherwise.
Posted : June 23, 2017 1:41 pm
