Topcon Hiperlite+
Hi, i an new to the forums and have finally found some place I can try and get help. I was laying out some structures yesterday and my Palm indicated that it had lost connectivity with my base. Upon going back to the base i soon found out that it was the rover and it was no longer displayed on my bluetooth connections. The Rx led on the far right no longer flashes. Is there a way to reactivate this without having to call Bunce and have them walk me through resetting com ports through USB?
Are you using TopSurv?
More specifics:
Data collector, what sofware?
Plug in to insure the system is running property and Bluetooth is the problem.
It sounds like the battery died and needs recharging.
:-O
more often than not with the Topcon is that you need to reconnect the radio through the data collector. it's an easy fix in TopSurv.
You see i wish I had all the components necessary before my colleague who handed it down to me took it into his own hands. I could've loaded the CDU program and tried to troubleshoot this. He called Topcon and they said to have it sent in. An $800 pop that I am put on.
