LOMA Zone A (no BFE)
10 Users
Illustrious Member Registered
Has anyone done one of these?
From what I read online FEMA will calculate BFE provided sections upstream and downstream of the structure provided in graphic and tabular form.
Which form is used?
Is there a online tutorial or would some be willing to share one of theirs?
Thanks.
Posted : 05/12/2014 10:25 am
(@wa-id-surveyor)
Prominent Member Registered
> Which form is used?
> Thanks.
I've done about 4 of these in the past few years but was not aware that FEMA would calculate the BFE. We used our in house engineers and provided them with the appropriate cross section/topo data to calculate the BFE. Then you simply plug in the BFE on your elevation certificate as you normally would and include the engineered report in your submittal. Haven't had any issues yet.
Posted : 05/12/2014 12:04 pm
(@rktman)
Eminent Member Registered
A few cross sections, put them in HECRAS with a flow and you have an elevation.
USGS regression flows work fine. Certainly a PE job (though it's not rocket science).
Posted : 05/12/2014 2:17 pm
(@clearcut)
Noble Member Registered
Then I suppose you don't mind when you hear a PE say that boundary surveying is easy. All you need is a handheld gps and a couple of coordinates.
Both have high liabilities if not done accurately with sound methodology. Both have numerous considerations far too complicated to state a generalized procedure in a single sentence.
Posted : 05/12/2014 2:25 pm
We run cross sections, send to PE, he sends back report with a BFE, and then we send in the info and have the structure removed.
I hesitate to get FEMA to send a BFE since so many of them are way off to begin with, maybe in other parts of the country it will work.
You need the cross sections sent to you in a report, and the engineer needs to explain his methods.
Posted : 05/12/2014 2:37 pm
(@clearcut)
> Which form is used?
> Thanks.
I have a time or 2 or more.
It depends on the locale specifics, the "approximate methodology" already developed, the office you're dealing with and what you are really trying to achieve.
Tabular form is a station/offset/elev depiction of each node of each cross section, allowing for easy data entry into the various modeling programs. Excel or similar spreadsheet works good.
I'm unaware of a tutorial. Like I said before, it kind of depends on the locale specifics on how best to approach it and what your particular FEMA office will be looking for. Broad alluvium v narrow gulch, small value rural structure v high dollar commercial, and so on are all important aspects of how to proceed.
And most of all, be fully aware of what the BFE is based on. I highly recommend a competent hydrologic/hydraulics engineer be involved. You want to be able to give your client an understanding of what his/her flood risk really is. Rating risk for flood insurance is one thing. Informing your client of the true risk of flood frequency and depth is unfortunately not always viewed as one and the same by those trying to get a quickie dickie BFE. Also unfortunate is that some may not fully understand what they may receive from FEMA as to whether it is simply a BFE for insurance risk rating, or if it is a confident value which you can educate your customer as to the true inherent risks.
I note you have the title "cfm" I also note that that title does not have anything to do with having an engineer's understanding of hydrology or hydraulics. Not being mean, just wanting to be clear.
Posted : 05/12/2014 2:49 pm
(@clearcut)
Moe,
you use the procedure I highly recommend.
Posted : 05/12/2014 2:50 pm
(@rktman)
Umm what...
I am a PE, LSIT with utmost respect for both professions (have done multiple Zone A, No BFE LOMAs)
Take a drink and chill, its almost the weekend.
Posted : 05/12/2014 2:55 pm
> > Which form is used?
> > Thanks.
Try this:
http://www.fema.gov/media-library-data/886edbc98e2229a90d0593d5e46ddac9/Data+Capture+Standards+Technical+Reference.pdf
DDSM
Posted : 05/12/2014 2:59 pm
(@rktman)
Forgot to mention, FEMA publishes the "ZONE A MANUAL" for those wanting to figure it out. Its a little dated since it refers to HEC2 and their Quick program, but it should give good background on how the BFE elevation is determined.
Posted : 05/12/2014 3:00 pm
(@john-harmon)
Reputable Member Registered
FEMA person on phone told me to leave the BFE slot BLANK, and say, "No BFE available
locally" and they will assign one.
I have seen the LOMA form that they sent the client later and a BEF is shown on the form and it is one tjhey came up with.
Posted : 05/12/2014 3:10 pm
> Umm what...
or one of these?
Posted : 05/12/2014 3:42 pm
(@clearcut)
Oh I'm pretty chill. I'm also a PE and LS who has developed a fair share of hydrologic and hydraulic models. There are some situations where getting FEMA to derive a BFE for Zone A is apprpriate. There are many that it is not and which would fall far short of the necessary due diligence one should apply.
Posted : 05/12/2014 9:42 pm
Here's one that I'm dealing with now: a subdivision was built on fill circa 1990. The engineering firm developed BFEs and got LOMR-Fs for the lots on the other side of a 200-foot wide greenbelt from my client's property, which was a remainder parcel and is now apartments. The local agency doesn't have any BFEs more current than those developed in the 1990.
The flooding source is a nearby drainage channel that runs parallel to the tier of lots leading up to the greenbelt; the area is pretty flat, so the BFEs as they approach the greenbelt descend by a hundredth or two per lot.
FEMA has remapped a couple of times since the '90s, and the current FIRM shows the Zone A line (no BFE) cutting through the building on my client's property. My client is pursuing a LOMR-F.
The original BFEs were NGVD29, which are shown in parentheses. (The conversion to NAVD88 is pretty consistent in the area at about 2.55 feet, which is the VERTCON value.) I'm tempted to extrapolate the BFE across the greenbelt. Any thoughts on whether or not FEMA is likely to see that as reasonable?
Posted : 06/12/2014 1:06 am
(@clearcut)
2 thoughts. First is you'll be accepting the liability of the quality of work of the firm that developed the BFE. It is notable that the firm's study is not adopted by the local agency or FEMA even though the data was accepted for the LOMAs. Its your decision if you have confidence in their numbers. FEMA likely will not contest your converted values.
The bigger question is your extrapolation method and whether it is a sound engineering determination of the hydraulic grade line. It is an engineering decision in CA Jim and you will be putting your CA LS license at risk if Ric or whomever replaces Ray catches wind that you're practcing civil engineering without a license. There is a huge liability in determining BFEs and it is important you understand how to correctly determine the hydraulic grade line and have reviewed the methodology the other firm used that you'll be hanging your hat on.
That said, yes FEMA will likely accept your proposed methodology.
Will it stand up in a civil action or before BPELSG?
Posted : 06/12/2014 7:01 am
Share:
