We have figured out linework in Trimble Controller using feature codes and attribute library and we are trying to get Carlson Survey to bring in the lines from the DC. Any suggestions?
PS-we do use field to finish already but our specific question is about getting the two synced if you will. thanks.
Posted : January 19, 2011 2:34 pm
Trimble does not export a DXF like the Carlson SurvCE. You will need to set the coding in your Carlson SW to match the Trimble definitions.
An easier method would probably be to export the Carlson definitions into Trimble format.
Posted : January 19, 2011 2:40 pm
THANK YOU FOR THE REPLY, WE ARE STILL PLAYING WITH THE TWO TOGETHER. I WILL TRY THAT EXPORT FROM CARLSON TO TRIMBLE.
Posted : January 22, 2011 8:36 am
