Leica Viva SmartWorx 5.5 version (CS15)
(@gregkogan)
Hi everyone,
I am running robotic Total Station TS15 with CS15 data collector with noted above software.
I do have an issue with point ID (numbers).
I would like always to have numerical point numbers so I set up at the begging of the job instead TPS0001 whatever point is going to be (next available point), but when I switch from one program to another(survey to stake out, etc) or utilize applications or change working style it just drops the last point and go back to TPS0001 again so I need to check what was the last point number and reset it every time(no sense).
Another thing when I create a first occupy point on new job as a result of resection and then trying to change the elevation of the calculated point the program doesn't allow me to edit the elevation of this point.
I was wondering if anybody was able to figure out how to deal with this matter (any work around).
Thanks.
Posted : March 29, 2015 6:59 pm
(@john-macolini)
It's been one of my nagging issues with the Smartworx software, that it doesn't remember the point number. Any time I go to a different screen, when I come back, it remembers the HR change, but not the point number or code.
Posted : March 30, 2015 5:07 am
(@gregkogan)
Yep.
It also happen when you change occupy and backside point number (move to new set up).
I did try a traverse application it might would work better with these matters.
Posted : March 30, 2015 5:20 am
(@zoidberg)
Does it not save your settings if you change the ID Templates in the Work Settings tab?
Posted : March 30, 2015 5:44 am
(@gregkogan)
Do you mean here:
Posted : March 30, 2015 5:58 am
(@zoidberg)
Nope. From your main home screen...
-User
-Work Settings
-ID Templates
Then you can set them for default ID names or you can change the incrementing to anything you want. Remove the letters and you should be good...? No?
Okay, I see where you were... I wouldn't create a new template but edit the default template to exclude letters... Does that work?
Posted : March 30, 2015 6:48 am
(@gregkogan)
This exactly what I had one step before my previous screen shot.
How it is going to effect on saving last point number when the program/set up will be switch?
Posted : March 30, 2015 7:19 am
(@zoidberg)
Ahh... There's the rub. I'm not sure how that would be affected.
There is an update in ver. 5.6 that allows you to change the point id of a surveyed point while you're in the stakeout screen... Not sure that will change anything for you though. I don't think that's really what you're having a problem with.
Posted : March 30, 2015 7:40 am
