write a description for a 50' wide easement adjoining the inside of all four sides of a 1000' x 500' rectangle?
You just did, practically.
A parcel is described sufficiently when that description is implemented and the parcel can be located properly.
B-)
Strip Easement, lying 50.00 feet right (or left) of the following...
Subject to or Dedicate a 50 foot wide,"what How would you...
Subject to or Dedicate a 50 foot wide,"what it is", easement around the exterior boundary of the above described tract and also recorded as Document Number 123 in the County Deed Records. Could be as many ways as there are types of easements, the description should be in sink with the existing Deed Documents or could be a stand along Document requiring more detail including the description of the parent tract. On a recorded Plat it could be graphically shown, labeled and dimensioned on the face of the Plat and dedicated within the owners declaration which requires a Notary.
jud
Here, I just say "The westerly (or whatever cardinal kinda almost) 50' of Lot XX, Block XX, XX Subdivision as recorded in XXX Recording district" I like those!
-JD-
Commencing at the old oak tree a smoke's distance from the spot where Willie Hagan shot Black Berta in 1888, then 50 feet to the right of and parellel with the following four boundary lines of said tract being described as:...................
