How to generate grid design points?
(@prariemorning)
How do you guys generate grid design points for an elevation grid of an area within an irregularly shaped piece of land? I use SurveyPro so I just have to line and offset the whole thing, but Magnet Field seems to have a Grid function under their Stake menu. I do not know if Magnet Field generates the points in a numbered way that is easy to walk, though. Many CAD programs can generate grid points but not in an order that you can actually walk out easily.
Posted : 14/08/2018 6:17 am
(@mvanhank222)
Is this for topo or layout
Posted : 14/08/2018 9:03 am
(@leegreen)
Sounds like the layout. If yes, then with Magnet use stake >points >nearest. After you stake a point press the -> arrow right button to stake to next nearest point. You can also create a point list to stake from. Tag and create points from graphics in the order you plan to walk.
Posted : 14/08/2018 9:21 am
(@prariemorning)
Layout
Posted : 14/08/2018 9:23 am
(@prariemorning)
Wouldnƒ??t stake nearest corner you in often? Thatƒ??s what happens to me when I use stake nearest.
Posted : 14/08/2018 9:26 am
(@leegreen)
Posted by: PrarieMorning
No, that has never happened to me with Magnet. You can use the next and previous?ÿbuttons to cycle through points.
Posted : 14/08/2018 11:23 am
(@prariemorning)
So when Magnet generates a grid the points are not numerically ordered in a walkable way??ÿ
Posted : 14/08/2018 12:01 pm
(@prariemorning)
Also, how large of grids have you tried surveying using the ƒ??nearestƒ?? method? I canƒ??t imagine how it would NOT corner you in by selecting the nearest one since a grid points are all the same ?ÿdistance away so Magnet would be arbitrarily setting your next point to stake.
Posted : 14/08/2018 12:04 pm
(@leegreen)
In Magnet create grid lines, not grid points.
Posted : 14/08/2018 12:17 pm
(@prariemorning)
So how does that work? Do you just select a line and then a station interval? Also, does it generate the lines strictly within a selected shape?
Posted : 14/08/2018 1:11 pm
(@leegreen)
Try it.
It creates infinite lines in map view. No snapping. You then walk to grid intersection. Show live coordinates, move pole to intersection and store. If you have pole on a wheel you can do an auto topo by distance, time or slope.
Posted : 14/08/2018 1:34 pm
(@prariemorning)
I canƒ??t try it because the firm I work for uses Trimble and SurveyPro, and SurveyPro has no gridding feature. I was wondering what other sureveyors use because line and offsetting a grid on a non rectangular area (irregular) is a headache.
Posted : 14/08/2018 2:17 pm
I would think that 'grid' isn't what you're actually looking for once your frame becomes 'irregular'.?ÿIf, by irregular, you mean a quadrilateral ??
What is the irregularity ??
Posted : 14/08/2018 3:19 pm
(@prariemorning)
A shape of any form essentially. It needs to be filled in with a set of design points in a grid formation so that I can go and get the actual elevations in a grid formation. How well does topconƒ??s solution for getting a grid work? That is, how user friendly is it??ÿ
Posted : 14/08/2018 3:30 pm
(@mvanhank222)
You could stake a DTM and use any line as the refrence centerline?ÿ
Posted : 14/08/2018 3:34 pm
