Hold the steel fence posts? or Ignore them? (Appology for a surveying related post, during all the other activities!)
22 Users
I will add, I also concluded that I'd have regrets either way.?ÿ
So, I'd have 2% less regrets via yielding to them. Regrets are inevitable. Less is better in this department.
Thank you,
Nate
Posted : 30/08/2020 2:06 pm
I have followed many of my own surveys and many more of others and when I go back, many things are not in the same place as I placed them and where I found them the first time.
Many times line posts have been moved from online to where my traverse hubs were, I say were because they drove the post down over the 60d nails.
When I can find original monuments, I use them and make the in between ones work with proration and thru the middle I mark a straight line even if my straight line does not line up with the various uncalled for stakes in between.
0.02
Posted : 30/08/2020 2:33 pm
(@jules-j)
Posted by: @nate-the-surveyor
Thank you,
Nate
You've made the best call for what's out there Nate. Been there done that, and have never been called out because of it. I think we as surveyors feel the stress upon ourselves. I've done many I just knew a call was forthcoming. Nothing! All we can do is locate the evidence, make the call and move on. I call it finding everything someone else could use against me. It's not your problem Nate. You went far beyond what a normal person would go. You're just the messenger. May the Lord be with you.?ÿ
Posted : 30/08/2020 3:29 pm
(@true-corner)
@thebionicman "...math is irrelevant." Good post!
Posted : 30/08/2020 8:26 pm
@paden-cash
Got 2/3" of an inch yesterday, hadn't had any of significance for over a month. Turned off my lawn watering system for at least the work week.?ÿ
Posted : 31/08/2020 9:37 am
(@kevinfoshee)
@nate-the-surveyor
I've always felt like found monuments make fewer enemies than set monuments.
Tough call, but, I promise to do likewise if I get a job in that subdivision ?????ÿ
Posted : 31/08/2020 10:03 am
Page 3 / 3
