Help with Trimble alignments
5 Users
(@lee-d)
I have an alignment in Civil3D that I've exported to a Trimble RXL file using Trimble Link. Everything looks fine, but the station equation didn't come over. No problem, I open the RXL in TBC and put in the station equation in the Alignment Editor. Now how do I save it? I don't see a Save option and the only Export options seem to require me to create a corridor. I don't need (or particularly want) a corridor, I just want to save the change to my alignment.
One would think that an "Alignment Editor" would offer the option to "Save Changes"... just sayin'
Posted : 21/01/2015 8:26 am
(@lee-d)
I managed to get my RXL fixed by loading it into Access and editing it in Roads, but you definitely shouldn't have to go through all of that.
Posted : 21/01/2015 9:15 am
(@ralph-perez)
I would reach out to Boris at Trimble and point that out, it may save some of the rest of us the headaches you just went through.
Posted : 21/01/2015 4:32 pm
(@lee-d)
You're right, I'm going to do that.
Posted : 22/01/2015 9:48 am
(@dan-steely)
The corridor export is an RXL file.
Just select your horizontal alignment, leave the rest blank and export.
Posted : 22/01/2015 12:25 pm
(@alan-chyko)
Not sure if it works, but did you try selecting the alignment only in the project explorer then exporting as a LandXML file?
Posted : 22/01/2015 2:57 pm
(@ralph-perez)
:good: :good:
Posted : 22/01/2015 3:22 pm
(@mojavegreen)
After you make the changes on the station equation you can just close the edit window and it automatically saves it. I just export using the "Corridor" tab on Export. Then choose "RXL road exporter from surface". I usually leave the surface blank and fill out the other information as necessary. I usually arrow down on the Settings button to review what station interval I want to use. It is listed as "Horizontal alignment st" change it to whatever stationing you want. You can not use a distance that is more than half your over all distance or it will give you an error. Then I just hit Export. All this info is if you don't have a DC hooked up at the time. If you do have one hooked up just bring up "Devices:Direct Connection" and hit the small export button and it will bring up "RXL road exporter from surface" and follow the rest of the instructions. Hope this helps.
Posted : 22/01/2015 3:32 pm
