GPS work
18 Users
(@neilrick)
My office is relatively new to the GPS marketplace and so we are trying to determine an appropriate field procedure for GPS work. ?ÿWe are currently using Topcon Hiper V equipment, and use Carlson SurvCE in our mini and Carlson Survey for drafting. ?ÿCurrently, we are starting a procedure where upon arrive on the job site we will set two control points using a MiFi and connected to our state plane coordinates. ?ÿWe then determine we will set up a Base Receiver over one of those coordinates and configure using the point number. ?ÿWe can then double check the coordinates for the second control point for tolerance acceptance, and any other control we have on the property.
We will then continue around the property and shoot in corners, roads, etc.
Does this seem appropriate, and will this procedure, once processed and adjusted using the SurvNET program in Carlson, keep our coordinates in state plane coordinates? ?ÿIn the past we have set up using Read GPS (unknown points), and then localized on the MiFi/State Plane points. ?ÿWhen doing this, after the adjustment process, if we returned and shot only using the Rover and not setting up and localizing, the points would differ by around 6-15 feet (it is my understanding this is because we did not set the Base over a known State Plane point).
Thank you for all your help and suggestions.
Posted : 23/01/2019 2:53 pm
Do you know what bearings you are on?
Nate
Posted : 23/01/2019 3:27 pm
(@neilrick)
So, we turn on the vectors from the Base to the Rover. ?ÿIs that what you mean? ?ÿSo, we have the vectors from the Base in order toe adjust the points.
Posted : 23/01/2019 4:02 pm
Are you applying theta, or not?
I've used Carlson data collector before. As I remember, you have an option to use state plane grid, or ground. Are you using either of those??ÿ
I used to use ground, THEN apply theta. To get Grid brngs, ground scale, at the base.
In an attempt to make field crew feel like kings, some of the calculations are hidden. This has the bad effect of hiding important metadata.?ÿ
I've not used Carlson in years, so I'd hazard a guess that it has changed some... But I don't know for sure.
I've migrated to Javad, and it gives me metadata, as I like.
Posted : 23/01/2019 4:32 pm
(@spledeus)
Run least squares by any chance?
Posted : 23/01/2019 5:06 pm
(@neilrick)
I did see the ground to grid option today. ?ÿI will look into that.
We run the lease squares data and that seems to be when the error occurs. ?ÿWhen I run the unadjusted coordinates into the software it matches up the the MiFi Rover shots, but once adjusted it goes off around 9 feet. ?ÿNot sure why.
Posted : 23/01/2019 5:43 pm
Doesn't the least squares report tell you what measurement is in conflict with the rest to give such a discrepancy?
Depending on where you are relative to your state plane zone, the discrepancy could be which kind of foot is selected?
Posted : 23/01/2019 5:59 pm
(@jkinak)
Posted by: NeilRick
Don't take this the wrong way but you would be smart to get some formal training.
The knowledge of the forum is great but you need to understand what's going on from the theoretical level on up... and it's highly unlikely that this is the place that you'll get the thorough foundation needed to develop sound processes, debug problems, and reliably deliver what your client needs.
Without that foundation, you'll have lots of sleepless nights wondering if your data is valid or not...
This isn't meant to discourage you - it's to point you towards hooking up with a good trainer for 3 or 4 week long sessions where you get to explore the topics being mentioned here. While that sounds like a big investment - it's nothing compared to the stress and cost of seeing poured concrete curing in the wrong location.
Posted : 23/01/2019 6:15 pm
I like what @JKinAK said.?ÿ
The fact that you posted the 1st post in this thread is a good indicator that your on the right track, and that your conscious is already niggling you. That's a good sign.
There is a good pile of knowledge to be learned. Many of us have a few feet of error somewhere.... From the learning process. Some of us have it, and still don't know where it is!
Nate
Posted : 23/01/2019 6:31 pm
Posted by: NeilRick
No, it's a little bigger than that.
It's the theoreticaly perfect north, that your particular "grid" is based on. You can use any north you want... Within some reason. And, you can make your gps do it.?ÿ
Some folks in the early days used "true north by gps". Problem is that true north is no longer true north. If you move east or west. True north is a series of converging lines, in the northern hemisphere. So, really, there is no such thing as true north, without telling us WHERE it's true. Move 1/4 mile east, or west, and you are not on true north. The lines that point at the north pole are converging. True north is ambiguous, without telling us WHERE it's true. We're surveyors. We get hired, to remove ambiguity, not inject into the title chain.
Nate
Posted : 23/01/2019 6:50 pm
(@bama7x57)
"Currently, we are starting a procedure where upon arrive on the job site we will set two control points using a MiFi and connected to our state plane coordinates. ?ÿWe then determine we will set up a Base Receiver over one of those coordinates and configure using the point number. ?ÿWe can then double check the coordinates for the second control point for tolerance acceptance, and any other control we have on the property.
We will then continue around the property and shoot in corners, roads, etc."
This is the method I have used since about 2001. It works well.
I have returned to projects years later and easily reproduce my results. I have shared coordinates on section corners with other surveyors and they have checked and matched my results.
It's a good idea to check into a NGS monument with good horizontal to confirm you have your data collector settings correct.
Posted : 24/01/2019 5:53 am
I frequently use GPS but rarely use localization. Set up your job to work in State Plane (or other appropriate grid projection system). Then just work in State Plane. Use localization only when you are obliged to adopt some legacy local coordinate system.
As an aside, I rarely use localization but I often use resection to locate my base or total station. I set my control?ÿ in convenient places around the perimeter of the site where it will be safe from destruction, then set my base or TS where it is convenient for the work at hand. But I insist on using 3 points to resect. So, in your work flow, I'd be setting 3 MIFI points.?ÿ
Aside #2 - it is really important to get your base in a really open area. That doesn't have to be right on site. As long as it is within radio range, you'll be good. Public parks, school yards (when school is out), freeway cloverleaf infields (well back from traffic) all make good base locations.?ÿ ?ÿ?ÿ
Posted : 24/01/2019 8:03 am
(@leegreen)
Also, suggest you always collect static at the BAse while performing RTK. This will give you a check on your VRS or RTN established base?ÿpoint, using OPUS.
Posted : 24/01/2019 8:10 am
(@wa-id-surveyor)
As JKinAK stated, please obtain some formal training either by another survey(preferred) or elsewhere.?ÿ You're on the right track by posting here but the intricacies of each GPS setup, software and hardware, will be important to master.
I would place understanding the grid to ground coordinate conversion and how your set addresses this at the top of the things to learn.?ÿ I have seen some nightmare coordinate setups on 90% finished projects.?ÿ the project was designed on grid but the control was on ground and also the other way around.?ÿ It all stemmed from the surveyor's lack of understanding of grid vs ground coordinates and how they worked with their equipment.
Posted : 24/01/2019 8:13 am
Formal training is great if you can get it. But I only ever got bits and pieces of it over the years. Some I got was really good (gpstraining .com -now defunct), and a lot of it was a waste of time and money.?ÿ If you were to ask me where to go to get it today, I couldn't really tell you.
So read all you can. Go youtubing, there is a lot there. Ask questions here. If some training opportunities present themselves, by all means, go for it.?ÿ
A couple of reading resources:?ÿ Javad GPS Tutorial;?ÿNGS - Real Time User Guidelines?ÿ; GPS For Land Surveyors?ÿ
Posted : 24/01/2019 10:28 am
