GPS is awesome sometimes
2 Users
45 acres of topo, started about 9 ended collecting just at noon, in between I had to keep changing the battery pack for the TSC2 cause it would give me the low battery you are about to lose all your data screen. It was 10F when I started and warmed up to 20F by noon.?ÿ
TOPO
Imagine how long that would have taken before GPS. And no where near the accuracy.?ÿ
Posted : 12/12/2019 9:16 am
(@ncsudirtman)
did you ride it with a ATV or side by side? I've seen a smaller Kubota tractor and the rover mounted up front above the counter weights that has been used several times before with great success actually, despite what some might think about a setup like that
Posted : 12/12/2019 11:50 am
@ncsudirtman
ATV, it works well, I have R8's the R10 is a bit more rugged. It can beat up the R8 if the ground is choppy so you need to pay attention to that, otherwise it is a smooth process. It has a mount on the left side of the front. Sits 4.3 feet above ground.
Posted : 12/12/2019 12:29 pm
(@ncsudirtman)
@mightymoe
gotcha, yea it sounds pretty sweet. post up a pic next time you hit the field with it!
Posted : 12/12/2019 1:11 pm
