QUESTION TO THE EXPERTS OF THIS FORUM, HOW DOES THE FIRMWARE UPDATE OF THESE GPS LOCUS ASHTECH AND SOKKIA ??
Well, I would not consider me self an expert... But those units are EOL.
Time to "move on". newer GPS time...
tigre5000i, post: 432388, member: 7350 wrote: QUESTION TO THE EXPERTS OF THIS FORUM, HOW DOES THE FIRMWARE UPDATE OF THESE GPS LOCUS ASHTECH AND SOKKIA ??
I have gps rtk trimble, but I want to throw these locus ...
Nate The Surveyor, post: 432425, member: 291 wrote: Well, I would not consider me self an expert... But those units are EOL.
If you are asking how to update.....
Install the newest version to the memory card
Install card
Turn on unit
There is no firmware update that I am aware of, nor will there be any forthcoming. If you are using Sokkia or Ashtech Locus receivers without any other brand/model mixed in the post processing attempt, the GPS files will process fine. The date and time will be incorrect, but otherwise the data will be the same. Those receivers apparently exceeded the largest numeric value for the GPS time stamp and started over at zero sort of like happened with some other brands recently.
Hongbo Niu, post: 432828, member: 9750 wrote: This is the firmware for Ashtech Locus. maybe it's helpful for you.
To load Locus firmware version LA00:
Download the following files to your PC:
Lcldr_20.exe
Loadirc1.bat
Locus.hexPut the Locus in Firmware Load mode by pressing and holding the power
button for approximately 10 seconds until the panel displays a
rolling red pattern. Leave the Locus in this state. Connect the
IR Cable to Com1 on the PC. Position the IR cable in front of the IR
port, as you would for the download procedure.From a DOS prompt run Loadirc1. This will start the Ashtech Locus
Program Loader.It will go through the following process:
Setting up interface
Preparing to send program
Loading Memory
Cleaning UpWhen finished program will say 'Load Complete...type any key to exit'.
To verify firmware load, connect to receiver with Solutions Download,
go to Receiver/Display Receiver Info.... This will give S/N and
F/W version.
Lcldr_20.exe
Loadirc1.bat
Loading Memory
F/W version.
Excellent, I owe you a drink !! ..., Greetings !! :clink::clink::):)
Looking for help to get the files listed for uploading firmware on the ashtech / sokkia locus GPS
doymcor@gmail.com
Maybe this??ÿ?ÿ https://surveyorconnect.com/community/gnss-geodesy/trimble-4000-ssi-week-rollover/#post-550309
